Shakedowns......
Old May 2, 2004 | 04:00 PM
Phil97SVT's Avatar
Phil97SVT
Default Shakedowns......
We finally got the nitrous system squared away/working correctly again and the fuel pump installation completed. Today, we did some testing with the TNT 100 shot and my current H & C(12.2:1 S2 heads|232/238 cam). Let me tell you this car is now a handful. :reddevil The corvette will now haze the ET streets in first and second gear without a problem. The logger showed slightly richer conditions than all motor and the timing a rock solid 30 degrees. Unfortunately the local welding shop was closed so the testing was done with a nitrous bottle that would barely read 650psi. After heating it up for 30 minutes it came to roughly 900psi which is a far cry from the 1100psi which is typical at the track on a fresh bottle.
Hopefully monday or tuesday I can get a fresh bottle and install the toilet bowl 150 jets. I just can't imagine this car with a full bottle and the 150 jets....Deep 10s high 9s should be a cake walk.
Phillip :steering:
Old May 2, 2004 | 04:10 PM
'97 C5's Avatar
'97 C5
Default Re: Shakedowns...... (Phil97SVT)
Way to go, Phil.
Good luck and keep us posted. :cheers:
