Low end cam?
Old May 2, 2004 | 10:21 PM
fmpros's Avatar
fmpros
Default Low end cam?
I notice that users reporting results of aftermarket cams all have great power increases but in the upper range. I don't drag race but would like more kick in the low and mid range. Is there a cam designed for such a thing?
[Modified by fmpros, 9:22 PM 5/2/2004]
Old May 2, 2004 | 10:32 PM
TrackAttack!'s Avatar
TrackAttack!
St. Jude Contributor
Default Re: Low end cam? (fmpros)
Sounds like a rear end gear change might be the better option for you. Just a thought...
Old May 3, 2004 | 07:46 AM
HITMAN99's Avatar
HITMAN99
Depends what you mean by low end. Most of those cams that show big top-end gains also pick up extra TQ from 2500 & up. It's below 2K RPMs where the power can lag. The simplest solution is to advance the cam. Most aftermarket grinds already come advanced two degrees, and on a bigger cam, another two degrees helps even more. What that does is open the intake valve a little earlier, helping low-end TQ and throttle response.
Comp Cams and others make an adjustable timing chain kit that will allow you to change the cam timing up to four degrees, without having to remove the cam.
Another approach that some use is to go with a narrower LSA. IMHO, this will improve the mid-range, but have little effect on low-end TQ. It will also make the idle a lot rougher, which some guys seem to like.
Old May 3, 2004 | 12:55 PM
Mr. Jones's Avatar
Mr. Jones
Default Re: Low end cam? (HITMAN99)
try the stock Z06 cam. Talk to a tuner about this cam it produces good torque.
I would go with gears instead of the cam, best money spent.
quick mod, good results and you didn't even open the motor.
3.73 with the auto will give it a nice low end feel.
Old May 3, 2004 | 03:55 PM
Goody's Avatar
Goody
I'd recommend newer gears as well. Best bang for buck I ever spent on my last A4 equipped Corvette. That was a C4, but the effect should be the same.
Old May 3, 2004 | 05:51 PM
Mirek's Avatar
Mirek
Default Re: Low end cam? (Goody)
224 on down should make you happy.
Old May 3, 2004 | 09:28 PM
FNFAST's Avatar
FNFAST
Default Re: Low end cam? (Mirek)
Gears, Gears, Gears!!! And a TC if it's an A4. That'll take care of the low end. A cam and headers will take care of the top end... assuming you have an intake and exhaust. Of course then you'll need new wheels and tires to get traction... :D :D
Old May 4, 2004 | 12:31 AM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
:iagree: Cam (For optimum torque in the low to mid-range on stock LS1 heads choose one with less duration than a 224) or Gears (3.73).
I recently did a cam only install - using the CompCams 220/220 .564/.564 114 from TSP, which gave me incredible RWTQ (376) with my stock LS1 heads! In fact my tuner wants me to return this Friday because he thinks he can pull more hp and tq out of her with a "conservative" tune.
Idles like stock and less expensive to buy/install than gears. However, now that I've got the cam I plan to get 3.90s later this year.
[Modified by AlohaC5, 7:34 PM 5/3/2004]
To Low end cam?
