Help with noise from drivers door...
Old May 3, 2004 | 06:54 PM
msuc5vette's Avatar
msuc5vette
Default Help with noise from drivers door...
I periodically hear what sounds like a relay clicking coming from the inside of my drivers door.
I also had codes for loss of comunication to BCM from both the driver and passenger door.
Old May 3, 2004 | 07:08 PM
Kenny94945's Avatar
Kenny94945
Default Re: Help with noise from drivers door... (msuc5vette)
I'd say you really should pull the door panel and see if indeed there is a relay or electrical clicking.
My guess would be that a cable is contacting the window. There is a TSB and in the factory manaul, as I recall, a section (under rattles and squeaks)
about zip tie-ing the cable in place.
Old May 3, 2004 | 09:28 PM
msuc5vette's Avatar
msuc5vette
Default Re: Help with noise from drivers door... (Kenny94945)
I'll have to listen when the car isn't moving, then I'll tear it down if need be.
What would cause a loss of comunication from my doors to the BCM?
Old May 3, 2004 | 09:41 PM
T_Vert's Avatar
T_Vert
the loss of communication codes are pretty normal and occur to everyone from what i've seen
dave
Old May 4, 2004 | 10:51 AM
carpe dm's Avatar
carpe dm
It could be a bad part, or bad connection. There is a connector in the black "accordian" tube between the door and the body of the car which may not be tight / connected properly. Worth a try. :yesnod: :)
To Help with noise from drivers door...
