Changing spark plugs?
Old May 3, 2004 | 08:47 PM
Tombone's Avatar
Tombone
Default Changing spark plugs?
Any tips?
Thanks. :thumbs:
Old May 3, 2004 | 09:09 PM
Old Rotor Head's Avatar
Old Rotor Head
Default Re: Changing spark plugs? (Tombone)
Get your wife or someone elses to change the back ones :D
Old May 3, 2004 | 09:43 PM
denscor's Avatar
denscor
Default Re: Changing spark plugs? (Old Rotor Head)
not as hard as it seems,the back ones are a little snug but if you use a swivel shocket it helps alot,I also remove the air tube hose off the headers, it makes it easier .there is a how to change the plugs on a tech site just do a search :chevy
[Modified by denscor, 2:45 AM 5/4/2004]
Old May 3, 2004 | 11:09 PM
gonbad's Avatar
gonbad
Default Re: Changing spark plugs? (denscor)
Go ahead and buy a set of new wires. You will probably break one or more of the stock ones getting them off. I broke two but was changing the wires anyways.
Old May 4, 2004 | 01:42 AM
blackbelt's Avatar
blackbelt
get some rubber hose it works great. :yesnod:
Old May 4, 2004 | 04:09 AM
TGKx's Avatar
TGKx
Default Re: Changing spark plugs? (blackbelt)
#7 will be your most difficult, you need to remove the air pipe (i had tpis headers and it was in the way, and a little bit of tubing, then use a short extension, long extension, deep socket, and ratchet and you should be able to hook onto it. The other side there is one where you need the short extension and a swivel i believe.
hope this helps.
Old May 4, 2004 | 05:48 AM
StoutMan's Avatar
StoutMan
Default Re: Changing spark plugs? (TGKx)
Changed em and POC (piece of Cake) with the right tools... Swivels brotha!
A 1/2 hr job and #7 is easy if you have a swivel... Or a swivel wratchet (sp) or 2 swivels... No sweat!
Old May 4, 2004 | 12:22 PM
JasonFRC's Avatar
JasonFRC
Default Re: Changing spark plugs? (StoutMan)
Heh.
I'm a Professional Technician/ Shop owner. It took me ALL of 45 minutes to change plugs the first time.
It's not easy the first time, but you learn the little tricks, and the next time is much smoother! Just give yourself plenty of time, and be patient. :D
Old May 4, 2004 | 12:31 PM
IM QUIKR's Avatar
IM QUIKR
Bandaids and lots of them.
Don't forget the antiseize on the new plugs or you'll end up doing it twice. The good news is it goes faster the 2nd time around. :lol:
Old May 4, 2004 | 02:00 PM
myblackC5's Avatar
myblackC5
if you have a lift, you can do the back plugs from the bottom. you don't have to take anyting off. use a two foot long screwdriver to reach up and pry off boots. just start with the hard ones first.......
:chevy
Old May 4, 2004 | 02:04 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Default Re: Changing spark plugs? (gonbad)
:iagree:
My wires were shot after 50k miles.
Old May 4, 2004 | 09:40 PM
1320dance's Avatar
1320dance
my buddy mr king 2 hours, with the wrong tools :seeya he always saves me money. that's a true pal :chevy
Old May 4, 2004 | 10:22 PM
Rob Razor's Avatar
Rob Razor
Default Re: Changing spark plugs? (1320dance)
90-minutes. 45-minutes for the first 7, 45-minutes for the drivers rear plug. BTW, Neosporin healed the cuts from that last plug in 1/2 the usual time!
Old May 5, 2004 | 12:05 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
I did a write up on the plug intall in the C5 tech tips (under tools menu at the top) section on the forum a few years back.
For wires I use Magnecors now and like them bettter.
[Modified by kewlbrz, 11:07 PM 5/4/2004]
To Changing spark plugs?
