Tire Tread Depth for Replacement
Old May 4, 2004 | 09:59 AM
willyIV's Avatar
willyIV
Default Tire Tread Depth for Replacement
What tread depth is the recomended replacement point for GY runflats? I know you can run them down as far as you want but at what point is failure an issue?
Old May 4, 2004 | 12:21 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: Tire Tread Depth for Replacement (willyIV)
Because the car has such wide tires for a, relatively, light car I don't take mine done much past 4/32. The light weight and big tread make the car a good candiate for hydroplaning. 2/32 is the legal limit most places. As far as runflats I would use any excuse to replace them! :)
Old May 4, 2004 | 01:21 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
2/32 legal in Pa... or two adjacent tread grooves below 2/32 fails.. :seeya
Old May 4, 2004 | 01:46 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
If you avoid the rain, run 'em til they're bald. They have more traction that way, ya know? :jester
Old May 4, 2004 | 03:00 PM
123Gone's Avatar
123Gone
Default Re: Tire Tread Depth for Replacement (Umrswimr)
Look at the large goove in the tire. You will see a "tread bar". The tread bar is a small raised portion in the groove. There is a tread bar every few inches. When the main tread is worn down to the tread bar, you need to replace the tire.
Old May 4, 2004 | 03:05 PM
2kbluestreak's Avatar
2kbluestreak
:iagree: Yes, as long as the roads are try, the minimum tread is OK. Get in a downpour with sheets of water on the road, and you'll know what the term "pucker factor" means. :cheers:
To Tire Tread Depth for Replacement
