Kooks install, which gaskits to use.
Old May 4, 2004 | 05:17 PM
jim-b-sr's Avatar
jim-b-sr
Default Kooks install, which gaskits to use.
I'm installing Kooks headers, x-pipe and hi flow cats on my 03 Z06. I purchased all new gaskits from Chevrolet as I feel these are better than those supplied with the headers. The gaskits supplied are of a Garlock material(I think) and the header gaskits from Chevy are metal crushing type, is this correct? Just want to use what works best... :smash:
Old May 4, 2004 | 05:47 PM
ragtopws6's Avatar
ragtopws6
Default Re: Kooks install, which gaskits to use. (jim-b-sr)
Just installed mine last week. Go with the GM gaskets, they work.
Old May 4, 2004 | 08:47 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
Can't you reuse the ones on the car?? MTI told me that would be the best thing to do with a low mile car, mine only has 12k on the odo.
Jim...i might have to make a trip across West "By God" after you get those put on and have ya give me a hand with my Kook's. :cheers:
Old May 4, 2004 | 10:17 PM
jim-b-sr's Avatar
jim-b-sr
Default Re: Kooks install, which gaskits to use. (cmb396)
Well, I was told you can use the old ones too, but I just decided for $30 I'd get new ones. I'll reuse the cat back gkts cause I just put the Stingers on 500 miles ago w/GM gskts. As for the install, I was going to do it myself, I have access to my buddies lift, but He didn't want to tie it up overnight and have to park his Porsche outside....... So I guess I'll save myself some skinned nuckles and have Fbodycentral do it in Jessup, Md. This week is going to go SLOW......
Old May 4, 2004 | 11:04 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
How much are they charging for the install?? The only place i could get around here wanted 600 bucks and 2 days to do it. :crazy:
Old May 5, 2004 | 01:03 AM
lowdowndirty's Avatar
lowdowndirty
I used the "paer" gakets for mine and they do leak a bit. (I seperated the stock ones when I removed them.) My advise is to use the stock metal ones...I think GM definately figured-out exhaust gaskets and these ones WORK. Chris.
Old May 5, 2004 | 03:12 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Kooks install, which gaskits to use. (lowdowndirty)
You guys are lucky" I'm still waiting for my Kooks. :sad: :leaving:
Old May 5, 2004 | 10:21 PM
jim-b-sr's Avatar
jim-b-sr
He told me approx. $450. I can live with that...
To Kooks install, which gaskits to use.
