C5 Power Antenna
Old May 4, 2004 | 08:56 PM
Jharms's Avatar
Jharms
Default C5 Power Antenna
My power antenna is on the blink. It always goes up but I have to push it to get it started to get it to go down.
Any suggestions on how to remove and replace?
Can I buy parts or am I better off just buying the whole thing?
Old May 4, 2004 | 09:03 PM
blktie8's Avatar
blktie8
Default Re: C5 Power Antenna (Jharms)
Mine did the same thing , had the dealer do it and it was warranteed .
Other cars I had that the antennas broke I replaced the whole thing
Old May 4, 2004 | 09:11 PM
Jharms's Avatar
Jharms
Default Re: C5 Power Antenna (blktie8)
Mine is a 98 and is out of warranty. I don't mind replacing the whole thing; in fact that was my initial plan. I was looking for remove and replace instructions on the forum and learned of a mast replacement that would fix the type of problem that I have.....but it was for a C4. Probably the same fix. But I still don't know how to start the process. I looked underneith the car and was able to see two small bolts, but I doubt that's all I have to remove to remove the module.
Again, any help on the remove and replace instructions will be greatly appreciated!
Old May 4, 2004 | 09:29 PM
Kenny94945's Avatar
Kenny94945
Remove the rear inner trim and the tail light. That should show you all the bolts and connections. Antenna asy. comes out through the tail light.
Old May 5, 2004 | 12:21 PM
white top's Avatar
white top
Similar problem with my 00 vert. there is a TSB that covers mine not sure about 98s. but the fix was easy and cheap. Replaced black bezel around mast cost about $7.00. Seems the rubber O ring in the bezel was too tight or expanded and put too much drag on the mast.
Jerry
To C5 Power Antenna
