THis seems to be a common problem w/ LS1 engines, and is often attributed to oil coming into the intake via the PCV. The early years had the PCV plumbed from the passenger side valve cover. On the later years w/ the LS6-style intake, the PCV is plumbed from the valley cover under the intake.
The only solution I have seen that really eliminates the oil contamination is to use a catch can. There is a home-grown version called the "Greddy", but others are also available.
What he said. Also the problem can get worse because so much oil is consumed that it burns into the piston and creates hot spots and pre-ignition. Lots of us have used an air compressor filter in line to pull out the oil before the intake and it seems to work well. Just do a search "PCV" in the archives.
:cheers:
I use the Shogun Industries "evacuation breather canister" ....a much better engineered product with internal baffles and filtering (it polished up beautifully). I had to make a polished aluminum mounting bracket, a 2 into 1 manifold and stainless lines, but is works great..... very nice looking unit. http://www.shogunindustries.com/cgi-...item=FC62601-1
We each are developing our own PCV catch system. We're learning that oil gets in the intake, it causes Knock and KR. Oil tends to flow to the back of the manifold into cylinder #7 which ends up breaking.
