Engine check light stays on
Old May 5, 2004 | 09:33 PM
Skidmark2004's Avatar
Skidmark2004
4th Gear
Default Engine check light stays on
I bought a 2004 z06 a couple of weeks ago. It has 600 miles on it. It has a Halltech Stinger intake on it. Any ideas why the engine check light stays on????
Old May 5, 2004 | 09:56 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Engine check light stays on (Skidmark2004)
check the codes are re-post. Some code is throwing the light.
Old May 6, 2004 | 12:50 AM
Richin Chicago's Avatar
Richin Chicago
http://www.c5forum.com/ayc/dtcdic.php
Old May 6, 2004 | 05:30 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
is the sensor plugged in?? or not tight?? common problem when messing around with the air intake
Old May 6, 2004 | 09:15 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Check these sites for more on codes:
https://www.corvetteforum.com/techti...D=26&TopicID=1
http://www.stengel.net/diccodes.htm
Old May 6, 2004 | 09:41 AM
Ranger's Avatar
Ranger
Happens sometimes when you mess with the air-flow, eg. change the intake.
As others have said, check the codes and write them down.
Next, clear all codes. This should turn off the "check engine" light.
Then drive the car for 10-20 miles, including some wide-open-throttle.
Now recheck the codes to see if any codes are "current," eg. labeled with "C."
If there are current codes, look them up at the links others have posted above.
Usually, the offending code was thrown by a transitory event related to changing the air flow when installing the new after-market intake. If so, it will disappear once cleared. If not, the likely issue is an air-leak that can be cured by tightening the connections. But if that is the case, you probably will feel a loss of power too.
Let us know what you find.
Ranger
[Modified by Ranger, 9:44 AM 5/6/2004]
Old May 6, 2004 | 04:32 PM
Skidmark2004
4th Gear
Default Re: Engine check light stays on (Ranger)
Thanks for the advice and links. Cleared the codes, Took it for a spin and rechecked...Looks good. Thanks :hurray:
To Engine check light stays on
