rear end change
Old May 6, 2004 | 12:04 AM
Cruzzn's Avatar
Cruzzn
Default rear end change
I have a 2001 coupe, with a A4. I want to put a 3.42 gear in. They tell me , I can use my stock converter and that my computer dosen't have to be reprogramed. Is this true.
Old May 6, 2004 | 12:19 AM
Mike Mercury's Avatar
Mike Mercury
Default Re: rear end change (Cruzzn)
yes, you can use your stock TC.
Yes, you will (more than likely) need to reprog your PCM.
What is your current rear axle ratio?
Old May 6, 2004 | 12:30 AM
Cruzzn's Avatar
Cruzzn
Mike, I am running stock 2.73.
Old May 6, 2004 | 12:28 PM
Mike Mercury
then reprog will be a must.
Old May 6, 2004 | 01:33 PM
JSTAN's Avatar
JSTAN
If you are gonna swap out the diff, I would install a TC and transgo shift kit. My .02$ :thumbs:
To rear end change
