Help-Busted Windshield Washer Switch
Old May 6, 2004 | 06:43 PM
Richy's Avatar
Richy
Default Help-Busted Windshield Washer Switch
I accidentally bumped into the pushbutton on the steering column stalk and
knocked the button out.The wipers & washer came on & could not be switched off.I pulled the fuse,but now I have no wipers.Does anyone know how to defeat the washer action & still have the wipers?I have a feeling the local Chev dealer is not going to have a replacement switch on the shelf.
Old May 7, 2004 | 04:56 AM
Richy's Avatar
Richy
Default Re: Help-Busted Windshield Washer Switch (Richy)
Unplugging the washer pump is not the answer since the wipers still run in
the intermittent mode with the fuse back in.
I can see inside the end of the stalk.The question is can I short something in there to fool it into thinking everything is OK?
Old May 7, 2004 | 10:01 AM
Bob's C5's Avatar
Bob's C5
Same thing happened to mine. The dealer replaced the stalk (Which was in stock. I was lucky.) under warranty in less than an hour.
Old May 7, 2004 | 11:50 AM
Richy's Avatar
Richy
Default Re: Help-Busted Windshield Washer Switch (Bob's C5)
Thanks,Bob.Just got back from dealers with new switch & new pump;both
warranty items.Turns out it was 2nd C5 in there with same problem.Now going to stock part.
Old May 8, 2004 | 06:53 PM
powderski13's Avatar
powderski13
I had the same problem in my 02 vert. The washer button just popped out while the car was in the garage. 2 tiny springs hold the contacts in place. Dealer replaced stalk under warranty.
To Help-Busted Windshield Washer Switch
