please,not again!
Old May 6, 2004 | 11:30 PM
ROD BROWN's Avatar
ROD BROWN
Default please,not again!
About 3 months ago,the check engine light came on and I lost all the power in my engine.i had the car re-tuned and I regained my power.today,the check engine light came on again and I lost all my power again.This is getting really expensive having the car tuned with the LS e-1 edit. Any suggestions to how I can correct this problem?The cycle seems to be about 3 months and the power is lost.Has this happened to anyone else?I checked the oil pressure,temperature.Every thing is normal. :chevy :chevy :flag :chevy :chevy
Old May 6, 2004 | 11:35 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: please,not again! (ROD BROWN)
Find out what the car is saying and post it
http://www.stengel.net/diccodes.htm
Old May 7, 2004 | 12:32 AM
ROD BROWN's Avatar
ROD BROWN
Default Re: please,not again! (Richin Chicago)
These are the codes I found:
U106 I couldn't find this code.
U1016 loss of communications
BORF Remote function actuation
RFA u1096 Loss of communications IPC
RFa1096 loss of communications BCM
Old May 7, 2004 | 12:44 AM
Richin Chicago
I think what you mean is U1016H U1064H and U1096H
If those are the codes just clear them and don't worry about them. I get them all the time. I have read that the trigger point for these codes is too sensitive and later models were corrrected. There are a zillion forum members that have chimed in on these over the yrears.
Old May 7, 2004 | 02:46 AM
ROD BROWN's Avatar
ROD BROWN
i just went to the store and the car wouldn't shift into reverse.i put the car into 1st gear and the car locked up.I played with the gear shift and finally got it into reverse and could back it out of the stall.i also notice my car doesn't have the positive shift when it shifts into second gear.i don't think the car is shifting from first to secnd gear.i lost the'snap from the transgo kit also.It shifts like it lost the shift points.When the tuner adjusted the shifting points with the LS E-1edit.I think thats why its gutless.I put the car in low gear and it locks up.Problems,problems. :chevy :chevy :flag :chevy :chevy
[Modified by ROD BROWN, 6:19 AM 5/7/2004]
Old May 7, 2004 | 09:23 AM
ROD BROWN's Avatar
ROD BROWN
No,suggestion? My car is setting in the street,waiting for 0800hrs to tow the car to the agency. :chevy :chevy :flag :chevy :chevy
Old May 7, 2004 | 09:43 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Rod, I do not know your specifics... the loss of communications is a common code... usually means a burp in the system,,, loss of communications to the PCm could, be a problem,,, its a trouble shooting issue... my first thought would be.. battery... is it new, old , original.. ? if it has been changed,,, do you know if it was leaking,.,... common problem.... and if so what kind of damage has it done... a little bit of acid leaking on the PCM could cause this failure... and it could have cause it months after the original battery was replaced.. with out knowing the specifics.. Im guessing battery or bad PCM... but ofcourse it could be many things ... battery and PCM are high on the culprit list, for the issues you describe
Old May 7, 2004 | 09:48 AM
ROD BROWN's Avatar
ROD BROWN
Default Re: please,not again! (Evil-Twin)
Would it make the transmission hard to shift?I douldn't get the transmission into 1st gear?When I put it into Drive,I could drive the car,but it doesn't seem to have any power,and the car isn't shifting correctly. :chevy :chevy :flag :chevy :chevy
To please,not again!
