Changing the coolant... (help)
Old May 7, 2004 | 07:16 PM
1999PewterCorvette's Avatar
1999PewterCorvette
Default Changing the coolant... (help)
Ok guys, Im gonna change the coolant in my C5 tomorrow. (the guy that put my cam in last week said the coolant seemed " a little thin"??). Anyways, the cars 5 years old, so time to change it. Two questions, how big of a catch can or bucket do I need if im just draining from the radiator?? Im not going to flush the whole system. Then after I drain it, do I add the same amount back in or just fill up the radiator and go all the way to the full mark on the overflow tank??
Thanks guys
Rob
Old May 7, 2004 | 07:58 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Re: Changing the coolant... (1999PewterCorvette)
Wait a minute... are you telling me the guy that put in your cam.... requires water pump and radiator removal... was so cheap as to return 5 year old coolant to your car.... then tell you it looked alittle thin.... can I have his name so as I can steer clear of this guy
Old May 7, 2004 | 08:03 PM
1999PewterCorvette
Default Re: Changing the coolant... (Evil-Twin)
Actually, he is an excellent guy. He was going to add new dexcool but he happened to be out. He automatically checked the car over, hes very thorough, thats why he noticed it. Asked me if it was ok to keep the existing coolant. I agreed so I could get my car back ASAP to enjoy the cam. Thats why Im changing it, I didnt want to wait for him to do it. Not a big deal.
By the way, do you have answers to my two questions??
[Modified by 1999PewterCorvette, 7:06 PM 5/7/2004]
Old May 7, 2004 | 10:17 PM
98silverC5's Avatar
98silverC5
You will get about a gallon and a half out of the radiator drain, which will drain the radiator and overflow tank. There will still be some coolant left in the block. To fill you use only the overflow tank, there is no access to the radiator. I would premix the coolant to the 50/50 mixture. Fill to the full level on overflow tank, idle car for one minute, install cap, rev to 3000 rpm a few times untill coolant reaches 210 degrees, stop motor, fill again if necessary (open cap slowly to release pressure), install cap, start and rev some more, do this until level doesn't change.
Old May 7, 2004 | 10:52 PM
1999PewterCorvette
Default Re: Changing the coolant... (98silverC5)
Thanks 98silverc5 for the info. :cheers:
Hopefully all will go well tomorrow.
Rob
1999PewterCorvette :cool:
Old May 8, 2004 | 04:16 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
see this thread..for a little more detail http://forums.corvetteforum.com/zerothread?id=140057
Old May 8, 2004 | 03:51 PM
1999PewterCorvette
Default Re: Changing the coolant... (pewter99)
Finished changing out the coolant this morning with no problems. Thanks guys for all your help. :hurray:
To Changing the coolant... (help)
