Can a new tire cause a pull?
Old May 9, 2004 | 12:17 PM
turboo2u's Avatar
turboo2u
Default Can a new tire cause a pull?
I had to mount a new tire on the rear passenger side which has a fair amount more tread than the driver's side rear. Could this cause a slight pull to the left? Thanx. :seeya
Old May 9, 2004 | 12:19 PM
Slickk.'s Avatar
Slickk.
Default Re: Can a new tire cause a pull? (turboo2u)
yes it can.
check the circumference, you may have introduced some stagger .
Stagger is good for circle track but bad for the road
Old May 9, 2004 | 12:29 PM
fast2000vette's Avatar
fast2000vette
Oh god yes, always replace in pairs. I have even had a difference in tire pressure cause the car to pull.
:seeya
Old May 9, 2004 | 01:36 PM
Bob50th's Avatar
Bob50th
Sure can, other than the previous causes mentioned I had a radial pull which was due to something with the radial plys in the tire. Switching it to the other side or the rear (all sizes being equal) might help if this is the cause of the pull. Just my .02
Old May 9, 2004 | 05:04 PM
ELIJAHCOLEMAN's Avatar
ELIJAHCOLEMAN
Default Re: Can a new tire cause a pull? (Bob50th)
make sure you check your air pressure, this will make it pull if you have one tire lower than another. :yesnod:
Old May 9, 2004 | 06:00 PM
dpd's Avatar
dpd
yea,you've got too much stagger in the rear.
Old May 9, 2004 | 07:31 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
Default Re: Can a new tire cause a pull? (Slickk.)
Just keep driving in a circle!!!!! :p:
Old May 10, 2004 | 10:12 AM
Duck916's Avatar
Duck916
This stagger can also cause premature wear of the clutchpack in the differential, since the right wheel will be turning slightly slower than the left. As said above, you should replace these in pairs.
To Can a new tire cause a pull?
