dic voltage
Old May 9, 2004 | 01:20 PM
wrustywrench's Avatar
wrustywrench
Default dic voltage
I was wonderin what is normal form the voltage display to read,, I thought mine used to read 13.6 or so,, but after blower install it stays around 13.2..is this normal,,,,,,,have redtop,,,seems like i lost some juice
Old May 9, 2004 | 03:59 PM
vrodri3978's Avatar
vrodri3978
Default Re: dic voltage (wrustywrench)
I have a 97 vette and the voltage reads 13.0 to 12.8 I guess this is ok i do not have any problems.
Old May 9, 2004 | 09:50 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
As long as the output is consistently above 12.5 vdc and holds there. It shouldn't really be a problem. Slightly older cars may show lower voltages due to bad connections/grounds/loose terminals.
Old May 10, 2004 | 07:41 AM
wrustywrench
Default Re: dic voltage (JoeyG)
Thanks, I wuz just gettin paranoid....
To dic voltage
