Help...Installing PIAA 1100s
Old May 9, 2004 | 02:52 PM
knewblewkorvette's Avatar
knewblewkorvette
Default Help...Installing PIAA 1100s
I am unable to pull up the links to the install :confused:
Can someone please tell me the best way to remove the factory lights and replace with the 1100s. I should be fine with the electrical part. Just how in the heck do you do the physical stuff :bb Do I have to remove the entire front end :skep: :conehead
Old May 9, 2004 | 02:58 PM
jmzvet's Avatar
jmzvet
Default Re: Help...Installing PIAA 1100s (knewblewkorvette)
Raise the headlights. Remove the black plastic housing around the headlight. Reach in down to the mounting bracket. Remove the bolt (10mm head I think) that holds the bracket. Unplug the light. Remove the bracket/light. Remove the factory light and adjustment hardware. Mount the PIAA light into the factory bracket. Install PIAA and factory bracket.
More info here: http://www.corvettedreams.com/piaa-i.pdf
[Modified by jmzvet, 12:03 PM 5/9/2004]
Old May 9, 2004 | 04:26 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
The best way i have found is, jack the front up and put on jack stands (or rhino ramps) take the 6 small screws from the access panel on each side. Everything you need to access is there for you. No cut up hands this way. :D
Bob
Old May 10, 2004 | 06:09 AM
EFI-1's Avatar
EFI-1
Default Re: Help...Installing PIAA 1100s (16Again)
knewblue, if you still need some instructions, email me and I'll send you my write up....dave@efiunlimited.com
Aloha, Dave
Old May 11, 2004 | 11:44 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Here you go. http://www.litewarehouse.com/pics/P-1100X-Install.htm Let me know if there is anything else I can do to help. :cheers:
Old May 11, 2004 | 11:47 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Do it from under the car, remove the access panels below the lights.
Old May 12, 2004 | 08:04 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Bob
:iagree:
Old May 12, 2004 | 09:47 PM
knewblewkorvette
Default Re: Help...Installing PIAA 1100s (Dr.Ron)
thanks guys :cheers:
I will post pics when I'm done
To Help...Installing PIAA 1100s
