Part Numbers for Fan Relays????
Old May 10, 2004 | 03:13 PM
Busa196's Avatar
Busa196
Default Part Numbers for Fan Relays????
My fan on my ATI kit quit working yesterday....It's either a bad relay, or a bad fan motor, so I'm going to start by tyring to repalce the fan relays. I have a few questions though....
aa) How many relays are there for the fan? ( I think 3?)
bb) If there's more than one, can I switch them around until I find the bad one?....or does each relay specific to a slot?
cc) Aren't they located under the hood on the fuse box?
dd) What's the part number(s)?
Many thanks for any help!
-Busa196-
Old May 10, 2004 | 04:41 PM
Busa196's Avatar
Busa196
Default Re: Part Numbers for Fan Relays???? (Busa196)
ttt :confused:
Old May 10, 2004 | 05:45 PM
mapman's Avatar
mapman
-Busa196-
There are 3 cooling fan fuses: COOLFAN3 (10 amp in#14), COOLFAN2 (30 amp in #46), AND COOLFAN1 (30 amp in #49).
There are 3 cooling fan mini relays: COOLFAN2 (in #43), COOLFAN3 (in #44), AND COOLFAN1 (in #45)
I do not know the part numbers. The cooling fan fuses and relays are under the hood. There is a diagram of the fuse block in the back of your Owner's Manual.
[Modified by mapman, 5:03 PM 5/10/2004]
Old May 10, 2004 | 07:45 PM
Busa196's Avatar
Busa196
Default Re: Part Numbers for Fan Relays???? (mapman)
Thanks for the info :cheers:
To Part Numbers for Fan Relays????
