Code: 10-PCM P1416 AIR System Bank 2
Old May 12, 2004 | 12:55 PM
Sneaky Fast's Avatar
Sneaky Fast
Default Code: 10-PCM P1416 AIR System Bank 2???? What is it???
What is the problem with this that I am getting Check Engine Light. I went into the Display Diagnostic to see what it was. Is it only a Dealer fix or can I do it? :confused:
[Modified by Sneaky Fast, 1:23 PM 5/12/2004]
Old May 12, 2004 | 01:46 PM
B. Stewart's Avatar
B. Stewart
Default Re: Code: 10-PCM P1416 AIR System Bank 2???? What is it??? (Sneaky Fast)
It is probably the check valve on the passenger side. They will rust and throw this code. Sometimes they will go away after you reset your pcm a time or two. Unfortunately the passenger side check valve is the most difficult to access as it is under the intake manifold.
Old May 12, 2004 | 01:52 PM
Sneaky Fast
Default Re: Code: 10-PCM P1416 AIR System Bank 2???? What is it??? (B. Stewart)
Would this just pop up all of a sudden, I was driving Monday and got out to go to the store and when I came back and started it up the check engine light came on?? Can I still drive it without issues, planning on taking it on a 3 hour road trip this weekend and it seams to be running fine! How do I reset it???
Old May 12, 2004 | 02:08 PM
B. Stewart's Avatar
B. Stewart
Yes it can just pop up. You shouldn't have any problem taking your trip. Just go back in and check for codes again and as you toggle through push reset and hold it down until it clears the code for each item. BTW have you installed headers lately? Mine started doing that after my header install, I replaced both check valves and the AIR pump and I will still get the codes from time to time.
[Modified by B. Stewart, 1:08 PM 5/12/2004]
Old May 12, 2004 | 02:19 PM
Sneaky Fast
No headers, for the air intake i have the K&N Y induction filter and changed the MAF housing and swaped out the corrugated tubing for the smooth tube infront of the Throttle body. Then just have a cat back exhaust and dyno tuned the computer.
So to reset I just go in where the codes are and start holding reset so they delete off and see if it comes back right???
Old May 12, 2004 | 02:50 PM
B. Stewart's Avatar
B. Stewart
That should do it. At times I will go for a couple of months without setting that code.
To Code: 10-PCM P1416 AIR System Bank 2
