cooler water temps
Old May 12, 2004 | 01:57 PM
DIAMOND DAVE's Avatar
DIAMOND DAVE
Default cooler water temps
Well I tried the 40 below water temperature additive and was added to the radiator as stated on the can.......2 cans and 19.95 a can plus 20.00 for the garage to do it and guess what.....Should have saved the money for more beer...Witch's ****, I think you could drink it and it would not even give you a bladder infection.......Don't recommend for either application...Same day application. :cuss
[Modified by DIAMOND DAVE, 7:57 PM 5/12/2004]
Old May 12, 2004 | 02:24 PM
Sandra Bigwoode's Avatar
Sandra Bigwoode
Default Re: cooler water temps (DIAMOND DAVE)
Well I tried the 40 below water temperature additive and was added to the radiator as stated on the can.......2 cans and 19.95 a can plus 20.00 for the garage to do it and guess what.....Should have saved the money for more beer...Witche's ****, I think you could drink it and it would not even give you a bladder infection.......Don't recommend for either application...Same day application. :cuss
where's that pt barnum when you need him...?
i am developing a fuel molecule 'alignment chamber' that uses magnets, copper windings and real crystals, it clamps around your fuel line; very easy to install.
i learned the secret of this device in north africa from an old bedouin cheiftan whose kindergarten teacher knew bill gate's aunt, which had been lost for thousands of years, the last time it was used was by the ancient egyptians on their anti-gravity sleds when they built the pryamids.
it increases hp by 25%, reduces fuel consumption by 24%, cures herpes and makes the driver irresistible to hot women. i am tweaking it to prevent irs audits and making the corvette invisible to state troopers... =;]
