Knock Retard and Traction Control
Old May 14, 2004 | 12:36 PM
G-lock's Avatar
G-lock
Default Knock Retard and Traction Control
I was playing with my Predator and doing some runs the other night and I was seeing KR down low and thru 2nd gear. So I was thinking the TC was pulling timing but I don't recall seeing that on the DIC. So the question is can the TC pull timing without sending a message to the DIC that the TC/Active handing is kicking in. Thanx, Jeff
Old May 14, 2004 | 04:09 PM
VetteDrmr's Avatar
VetteDrmr
Default Re: Knock Retard and Traction Control (G-lock)
I don't think so. TC does pull timing as well as shut off fuel, so you might have just missed the message. OTOH, I've never had TC engage where it wasn't immediately obvious, so you might have been having some detonation that the PCM pulled timing for.
HTH, and have a good one,
Mike
