Driveline Broke - Need Input
Old May 14, 2004 | 01:45 PM
C5 Tweaker's Avatar
C5 Tweaker
Default Driveline Broke - Need Input
I did an agressive shift to 3rd and heard loud grinding. Now I hear what sounds like slipping splines, probably in front, at anything over quarter throttle. I just limped it to the house and have not had a chance to open anything up yet.
Is anyone aware of any 'common' failure point? It sounds like clutch plate to torque-tube shaft slippage, but I guess it could be torque tube to trans as well. The transmission 'feels' fine (smooth under motion and smooth gear changes).
Thanks in advance for any input.
(car is 435+ RWHP M6)
Old May 15, 2004 | 11:08 AM
gonbad's Avatar
gonbad
Default Re: Driveline Broke - Need Input (C5 Tweaker)
Possibly broke the front bushing on the torque tube. Good luck!
Old May 15, 2004 | 10:26 PM
C5 Tweaker's Avatar
C5 Tweaker
Default Re: Driveline Broke - Need Input (gonbad)
You are probably correct - thanks.
Luckily the torque tube exterior appears to be intact, unlike the one in the following link:
http://www.breathlessperformance.com...ts/100-504.asp
Anyone have any experience with the aluminum replacement bushing? Increased vibration or noise?
Old May 15, 2004 | 11:26 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
I just did mine the front bushing was literally dust and fuzzy string. The bolts were the only thing grabbing it was hard to tell if it was the front or the back until it was apart. It had 60+ on it with some drag and mostly road racing. I put a new torque tube, You can only use an aluminum bushing on one end. What year car and miles? Tube was 1600 and the new ones are stronger than 99 MY. i did a clutch and slave while in there and the clutch was starting to burn and chip away.
I power shifted mine at the last track event in Nov then heard a clank when I went forward to reverse and knew it was bad. Then I decided I was in a hurry to get to a event and had the tube next day aired :eek: along with the LGM headers.
[Modified by John Shiels, 11:28 PM 5/15/2004]
[Modified by John Shiels, 11:31 PM 5/15/2004]
Old May 16, 2004 | 08:12 AM
69's Avatar
69
Cruise-In VI Veteran
Default Re: Driveline Broke - Need Input (John Shiels)
Holy Toledo John! Your are lukcky that shaft did not exit the tube and find it's way firmly up your @ZZ!
Now you got me thinking about lining my tunnel with Kevlar.
Kevin
Old May 16, 2004 | 11:22 AM
James G's Avatar
James G
Hey John,
How difficult is it to replace the F&R bushings ? I have a harmonic vibration from 2700 - 3000 RPM, although no vib from 3k to 5500 or below 2700
The only thing I can think of are worn bushings. :rolleyes: :rolleyes: :rolleyes:
Old May 16, 2004 | 11:43 AM
C5 Tweaker's Avatar
C5 Tweaker
Thanks John!
The issue is with a 2001 that already has the improved assembly. The car has 50k miles and sees severe duty daily with 435+ RWHP and 335s out back.
As the bushings are not available from GM, the shaft assembly with the bushings is $1100, or the whole torque tube for $1,900. I sent an email to Unidrive to probe for possible bushing sources.
I fear that if I replace one busing with aluminum, the other bushing may already be on its last leg. I may decide after inspection.
I found a junk yard torque tube for $450, but I am very skeptical that it would be perfectly strait from a totaled vehicle.
Tough choices...
[Modified by C5 Tweaker, 10:46 AM 5/16/2004]
Old May 16, 2004 | 08:28 PM
69's Avatar
69
Good Luck with Uni-Drive, they were no help for me. Uni-Drive stated that the shaft is balanced as an assembly (which makes sense).
Before you buy any parts, inspect everything first….you many only need the drive shaft assembly, but if the shaft bearing spun in the torque tube then you will need a complete torque tube assembly.
To Driveline Broke - Need Input
