A sign the Differential is going bad?
Old May 15, 2004 | 09:58 PM
blu00rdstr's Avatar
blu00rdstr
Default A sign the Differential is going bad?
There's a severe sudder when nailing it hard in a turn. Is the diff going bad? Nailing it in a straight line lights up both tires.
Old May 15, 2004 | 10:55 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: A sign the Differential is going bad? (blu00rdstr)
You ahve 16 clutch discs in the diff that engage off and on during a turn... it could be that the clutches are worn... have you tried to change the oil in it to see if big chunks of clutch disc are falling out?
VR :cheers:
Old May 15, 2004 | 11:43 PM
blu00rdstr's Avatar
blu00rdstr
Default Re: A sign the Differential is going bad? (vetterdstr)
...have you tried to change the oil in it to see if big chunks of clutch disc are falling out?
Not yet, I should have thought of that since I just did that with the blower.
To A sign the Differential is going bad?
