Coupe hatch problem
Old May 16, 2004 | 06:48 PM
Old Rotor Head's Avatar
Old Rotor Head
Default Coupe hatch problem
Anyone have a solution for this? Up until last week I could open my hatch with the motor running by pulling up on the emergency brake. All of a sudden this doesn't work anymore. The hatch still opens with the button if the motors off. A PIA when I'm dropping my son off at school.
Old May 16, 2004 | 07:29 PM
JCR's Avatar
JCR
Default Re: Coupe hatch problem (Old Rotor Head)
Check the emergency brake switch . Is the light on ?
Old May 16, 2004 | 08:08 PM
Old Rotor Head
Default Re: Coupe hatch problem (JCR)
JCR thanks for the response. Nope no light?
Old May 16, 2004 | 08:35 PM
dezcapt51's Avatar
dezcapt51
can't you just push the little button :confused:
Old May 16, 2004 | 08:38 PM
Old Rotor Head
Thanks JRC problem fixed. Add brake fluid ;)
FYI found out that this is a design feature (dash emergency light does not come on) to give you a heads up that your pads are worn and need replacing. Great forum.......GREAT CAR
Old May 16, 2004 | 09:11 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
________________________________________ ________________________
How did you find out about this feature? I love it when I find out something I didn't know before.
Old May 17, 2004 | 06:25 PM
Old Rotor Head
Default Re: Coupe hatch problem (6SPD98)
From a Forum Search:
Help - Parking brake light comes on during accelleration (SDVette) 5:53 PM 8/28/2002
If the fluid level is down, don't just immediately fill it - check your brake pads, front and rear. The brake system will use more fluid as the pads wear and the calliper pistons must extend further to slow the car.
Old May 18, 2004 | 06:31 PM
Lancer033's Avatar
Lancer033
It's also an indication that there is a leak in your break system somewhere, I had that problem a while back when i had the calipers off to install rotors. One of the break lines didn't seal properly and fluid was leaking. I found that out when i went for a test drive. fortunately, I was close enough to home to get back before the master was empty.
Old May 18, 2004 | 08:30 PM
Old Rotor Head
Default Re: Coupe hatch problem (Lancer033)
:eek: Thanks for the heads up
To Coupe hatch problem
