DIFFERENTIAL LEAKS
Old May 16, 2004 | 09:36 PM
carman1's Avatar
carman1
Default DIFFERENTIAL LEAKS
I'm not sure you even call the rear end a differential any more but??
Anyway my 03 Vert developed leaks in the rear end. Only 4000 miles!
Only car I have ever owned that developed leaks, let alone when it was almost new. This includes, Mercedes, Mustang and Cad.
Any thoughts from my fellow forum members?
Going to the dealer Monday. So if anybody wants to share their experiences before I go it would be appreciated
Thanks :nopity
Old May 16, 2004 | 09:50 PM
z0sense's Avatar
z0sense
Default Re: DIFFERENTIAL LEAKS (carman1)
Super common problem with the Vettes.
Most likey it needs axle seals....it will be covered under warranty.
Old May 16, 2004 | 10:04 PM
kuruvette's Avatar
kuruvette
Get in line. Well known problem with the vette. You can do a search on this extensive topic. The dealership should know about this problem. :mad :mad
Old May 17, 2004 | 11:21 AM
sasunlover's Avatar
sasunlover
If it's still under warranty, let them worry about it, otherwise, try tightening the bolts surrounding the seal. Noticed a leak in mine during the last oil change at the dealer and the mechanic tightened all the bolts and it seems to have cured the problem.
Old May 17, 2004 | 01:23 PM
pewterhdtop's Avatar
pewterhdtop
Default Re: DIFFERENTIAL LEAKS (sasunlover)
Had the leak, got it fixed under extended warranty. They forgot to add the limited slip additive! Several others have had this problem as well. I suggest that you double check the paperwork, and ensure that it was added and listed on the bill. Do not let them try and tell you it is not required, with the GM fluid, it is mandatory. :smash:
Old May 17, 2004 | 05:14 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
I have the same leak problem (albeit very slow leak...) on my 2004 and will have it fixed under warranty. GM should have corrected this common problem over the 7 years the C5 was produced! :mad
Old May 18, 2004 | 11:30 AM
carpe dm's Avatar
carpe dm
Default Re: DIFFERENTIAL LEAKS (AlohaC5)
This was a problem from the beginning, but GM continued to accept poor cases from the supplier, rather than slow production. It could just be some blow-by from the vent. Clean it up and keep an eye out for a repeat. Good luck. :)
Old May 18, 2004 | 12:19 PM
DoctorV8's Avatar
DoctorV8
Default Re: DIFFERENTIAL LEAKS (carpe dm)
My 2001 coupe had this issue, and my 2004 Z06 does too, with only 5,000 miles on the odo.
Old May 18, 2004 | 03:35 PM
VETFVER's Avatar
VETFVER
Dealer fixed mine...finally and so far so good. With the new GM bulletin came the correct parts for the fix!
I am VERY pleased with the folks at Quality Chevrolet, Escondido, CA.
Dan
Old May 25, 2004 | 06:33 PM
vectorz's Avatar
vectorz
Anyone know how much aprox it costs to fix the differential leak at the dealer?
Old May 25, 2004 | 08:24 PM
C5naples's Avatar
C5naples
Default Re: DIFFERENTIAL LEAKS (vectorz)
I have a bid from the local chevy dealer to repair both sides for $604.54
To DIFFERENTIAL LEAKS
