Mcleod knowledge needed
The next few hundred miles were all on the street and while there was some aggressive shifting, nothing really that bad. No clutch dumps or anything. The first time on the strip it died after the 6th pass. Four pass using line lock burn outs to heat the tires and the last pass the line lock burn out I'm told was with the tires (NOT SPINNING), rather the clutch smoking. I still ran hard, but it would not pull after I tried turning around at the end of the strip.
I'm looking to try and learn what happened to my clutch. Just do not want to repair/replace and do it again. Advice/thoughts appreciated.
2k1vert
[Modified by 2k1vert, 4:58 AM 5/18/2004]
VR :cheers:
[Modified by vetterdstr, 6:20 AM 5/18/2004]
VR :cheers:
1) Were you at the Drag Strip when it went out - Yes
2) Did you burnout or launch around 3000-3500 rpm - Yes
3) Where is your peak power randge? - 3500-4500 (based on poor memory)
4) Did your tires spin when it happened? - No, based on spectators my clutch was pouring out smoke but tires were hooked.
5) Did it happen when you were warming up the tires - Yes
I was told the problem was that I launched at too low RPM. That I should launch 1500RPM above where I make max power to ensure that the power needed to break the tires loose occurs, so he said using 4500 RPM as max power that I should be launching at 6000RPM. There is no way in heck, that I'm gonna take a stock drivetrain (shafts) and launch on hot tires at 6000rpm.
Now, I will be scared to do line lock burnouts or launch off the line for fear of having to tear everything out again. I had the mindset that the clutch would have no problem talking the power I have. Les indicated to me that launching that low and tires sticking forces something to take the punch. The clutch, rearend, shafts or torque tube. I guess it makes sense, but I still feel like I do not know how to protect myself the next time around short of just don't dump the clutch. :nopity
So Red @ McLeod can make it better than new? So it will handle much more abuse?
I've had my tuner modify my torque management settings in the PCM. As I recall to prevent it from pulling to much timing or reduce the amount of time it takes to regain timing after it happened. I can't remember what exactly right now.
Thanks for your advice VR.
Regards
2k1vert
[Modified by 2k1vert, 10:58 PM 5/18/2004]
If you can, let me know what shafts you feel should be upgraded. I don't want to give up burnouts and I'm very nervous about tearing things up. If there is 1 or more shafts that I should be concerned about, then I'd like to try and cover that before it goes back together.
Thanks again
Richard :cheers:
DO you happen to have an adjustable master cylinder? How far off the floor does the clutch engage?
I may take you up on the half shaft. I want to do a little more reseach to see roughly what percent of the folks break which shafts. I believe I have read it is primarily the one you mentioned, but I would like to know how often the other breaks, how often the output shafts break etc.
Thanks :cheers:
There are 2 output shafts in our rear end.
A short side (not available from anyone yet) and a long side (the one that breaks 99.9% of the time)
I have not ever seen anyone break a short side output shaft, although I heard about one person doing it.
Fact is that with 600+ RWHP cars the short side is not a problem.
About your master, I was thinking it could be adjusted improperly, which would cause the problem you were having. Since you are putting a new clutch in anyways....double check to insure it is adjusted properly.
[Modified by z0sense, 11:54 PM 5/18/2004]
Interesting you are saying you can tell the one disk is being engaged at 3" and the other at 5". There really should be little indication that there are two disks in the setup. I wonder if the floater may need to be shimmed differently than how you have it. Other than the clutch having a little more pressure and more grip, it should drive exactly as a single disk would. Did you tell Red this information at McLeod? This would also explain how you were able to burn up one disk by slipping the clutch.
Chris
Thanks everyone for your comments.
2k1vert
