Helo Gear carrier question
Old May 18, 2004 | 02:46 PM
SlickVic's Avatar
SlickVic
Default Help Gear carrier question 2000 6 speed to 2002 A4
Can anyone shead some light
I have a 2002 A4 and just got a 342 from a 6 speed car and the shop that is doing the install says it wont fit???
Is that True??
Please help as they want more money for a new carrier and its not in the budget right now
Thanks for your help!!
[Modified by SlickVic, 1:47 PM 5/18/2004]
[Modified by SlickVic, 1:50 PM 5/18/2004]
[Modified by SlickVic, 2:09 PM 5/18/2004]
Old May 18, 2004 | 02:52 PM
mwittkopf's Avatar
mwittkopf
Default Re: Help Gear carrier question 2000 6 speed to 2002 A4 (SlickVic)
Yes, it will fit. They must remove the adaptor from your old rear end (it looks like a round disc with an o-ring around it. Other than that, they are interchangeable! You also need a reprogram on the auto or it will not shift correctly.
Mike
Old May 18, 2004 | 02:58 PM
SlickVic's Avatar
SlickVic
Default Re: Help Gear carrier question 2000 6 speed to 2002 A4 (mike@xtreme)
Yeah I know I had to reprogram but they say it wont bolt up
I sent them an email I hope they figure it out
Thanks again!!
Old May 18, 2004 | 03:01 PM
Mike Mercury's Avatar
Mike Mercury
:iagree:
it will fit; but the "seal plate" needs to be removed from the front (transmission) end of the diff and placed back onto the 3.42
I think I have a pic of the seal plate and the rubber seal part numbers on my web page: http://mikemercury.home.att.net/342.htm
Old May 18, 2004 | 03:05 PM
Mike Mercury
Default Re: Help Gear carrier question 2000 6 speed to 2002 A4 (Mike Mercury)
here is a pic of a 3.42 without the seal plate installed:
and here's a pic with the 6" aluminum seal plate installed:
[Modified by Mike Mercury, 3:07 PM 5/18/2004]
To Helo Gear carrier question
