need help installing hal/qa1 shocks
Old May 19, 2004 | 07:32 PM
pdd000's Avatar
pdd000
Default need help installing hal/qa1 shocks
do i just put them on the car or do i have to adjust for height. any help appreciated. also whats the torque specs for the bolts to the shocks. thanks pat
Old May 19, 2004 | 11:10 PM
pdd000's Avatar
pdd000
Default Re: need help installing hal/qa1 shocks (pdd000)
TTT :seeya
Old May 19, 2004 | 11:43 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
I set them to 1 on each so they are easy to pull. Loosely put the bottom bolts on an pull the shaft up to the top. Tighten up.
I was a little carless an did not torque. I did got back in next day to make sure they were tight and check each time I swap wheels.
Put the rears in with the **** facing inside of the car so it is a little easier to adjust.
Old May 20, 2004 | 05:23 PM
pdd000's Avatar
pdd000
Default Re: need help installing hal/qa1 shocks (REDGAR)
thanks for the tips :cheers:
To need help installing hal/qa1 shocks
