General header post install questions.
Old May 21, 2004 | 08:39 AM
Heretic's Avatar
Heretic
Default General header post install questions.
While installing my LTs I noticed that some crucial wiring and parts are pretty close to the primaries. Someone here recommended thermotech self adhesive insulation, but what all should be protected for long term reliablity?
I was thinking about the O2 wires and the clutch and brake lines on the drivers side. Anywere else?
Old May 21, 2004 | 08:57 AM
Bill Reid's Avatar
Bill Reid
Default Re: General header post install questions. (Heretic)
Some of the wiring can be moved and tied up out of the way. For the clutch line you can use Kool Sox... the same sock folks use to insulate their spark plug wires. If you want to wrap the brake lines you can use the same material and hold it in place with safety wire.
:cheers:
