Need some Help! Guys!!
Old May 21, 2004 | 07:37 PM
Vegas Vette's Avatar
Vegas Vette
Default Need some Help! Guys!!
Well I went out to clean my baby up today and low and behold the passenger side window will not go down all I hear is a clicking coming from the door does anyone have any idea what it could be??
Old May 21, 2004 | 11:58 PM
Vegas Vette
Default Re: Need some Help! Guys!! (razor2430)
TIT! Anybody...
Old May 22, 2004 | 01:09 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
sounds like your actuator died...both switches do this??
Old May 22, 2004 | 03:52 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Exact same thing happen on my 00 coupe. Actuator. It seems to be a popular problem.
Old May 23, 2004 | 05:19 AM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Unfortunately this is a very common problem on the passenger side window.
Happened to my '04 C5 with only 6K miles at the time. I had it fixed under warranty. If you do a search - you will find this has affected several of us.
I'm not sure what the cost would be if out of warranty, but the repair can be done in half a day. Good luck!
Old May 23, 2004 | 05:49 AM
markcz's Avatar
markcz
Default Re: Need some Help! Guys!! (AlohaC5)
Try this!
:cheers:
Old May 23, 2004 | 10:36 PM
Vegas Vette
Default Re: Need some Help! Guys!! (markcz)
Thanks for the input guys I had to pull the door panel off to check it out. I did a search and found some good info. I tapped the motor and she works as advertised what a pain in the butt.. But its good to go!!!
To Need some Help! Guys!!
