Fuel Filter Location
Old May 22, 2004 | 09:40 PM
Doughan's Avatar
Doughan
Elite Member
Cruise-In III Veteran
Default Fuel Filter Location
Okay, I must be blind. I don't easily see the fuel filter on the LS1. Where is this critter located?
Old May 22, 2004 | 10:12 PM
GraveDigger's Avatar
GraveDigger
Default Re: Fuel Filter Location (Doughan)
Fuel filter is located just over the rear axel on the drivers side.
Tod :seeya
Old May 22, 2004 | 10:19 PM
silverhead's Avatar
silverhead
Just replaced mine. It is on the inboard side of the driver's side fuel tank. There are fuel tank shields covering the bottom of each fuel tank. Remove the shield (five bolts). It is best to get the car up in the air. The filter is bolted directly above the driver's exhaust on the side of the fuel tank. Mine (1997) had one line going in and one line exiting, round and about 2 inches in diameter. The exiting connection developed a serious/dangerous leak.
New factory filter cost me $13.95.
Good Luck.
Old May 22, 2004 | 10:21 PM
Patches's Avatar
Patches
Old May 22, 2004 | 10:29 PM
Doughan's Avatar
Doughan
Elite Member
Default Re: Fuel Filter Location (Patches)
Great pic and thanks for the replies! :cool:
Old May 23, 2004 | 01:03 AM
SMOKNC6Z06's Avatar
0SMOKNC6Z06
Former Vendor
97-98 use a plastic fuel filter. The 99-03 use a different style metal filter. Be prepared to pay about $50 for the filter if you have the 99-02.
Old May 23, 2004 | 04:28 PM
Lancer033's Avatar
Lancer033
Default Re: Fuel Filter Location (SMOKNC5)
how often should those be replaced
Old May 23, 2004 | 07:10 PM
Autoworker's Avatar
Autoworker
Default Re: Fuel Filter Location (Lancer033)
The General says dont change unless you have a problem. I changed mine @ 50,000 miles when I had the exaust off.
Old May 23, 2004 | 11:21 PM
Lancer033's Avatar
Lancer033
Default Re: Fuel Filter Location (Autoworker)
I'm getting a very slight knock sometimes when i get gas on base, would changing it out possibly help with that. Only reason i don't just get gas off base is that it costs more than twice as much
Old May 26, 2004 | 09:59 AM
jimcork1's Avatar
jimcork1
The fuel filter should have nothing to do with Knock. I suspect low octane and the knock sensor is retarding the spark. If you buy gas on base,, consider 3/4 on base 1/4 off base of prem. to see if it helps with knock.
If you are getting knock,, Do not use heavy throttle on acceleration until you solve the knock. If 3/4 1/4 doesn't work, you might try a different blend.
PS.. I was at RM 74 so I understand $$ on gas
To Fuel Filter Location
