Help hooking up DRM oil cooler
Old May 23, 2004 | 12:32 AM
BH's Avatar
BH
Default Help hooking up DRM oil cooler
I am installing a DRM radiator oil cooler. I need to know which line out of the adapter above the oil filter is out and which is the in line. I assume the out line goes to the bottom of the cooler.
Old May 23, 2004 | 12:58 AM
SNW Vette's Avatar
SNW Vette
Default Re: Help hooking up DRM oil cooler (BH)
Hi,
The forward port is "out". It is connected to the pump through a passage running aft through the block.
Good luck,
Steve
Old May 24, 2004 | 01:27 PM
JakeL's Avatar
JakeL
Somebody else can correct me if I'm out of line here, but I don't believe it matters whatsoever.
Cheers!
-J
Old May 24, 2004 | 01:54 PM
LG Motorsports's Avatar
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: Help hooking up DRM oil cooler (JakeL)
there are only two reasons that it would matter is if there is a remote oil filter. You don't want the oil trying to enter the filter from the center because of the one way flapper built into the filter.
The other reason is to fill up the oil cooler from the bottom so the cooler is full rather than having air pockets in the cooler. you will get better heat exchange with a full cooler. This also depends on your cooler design and installation layout. If your cooler is part of the radiator, then plumb it in from the bottom fitting.
LG
To Help hooking up DRM oil cooler
