C5 Coupe Alignment Specs
Old May 23, 2004 | 02:44 AM
LBear's Avatar
LBear
Default C5 Coupe w/ F55 Alignment Specs
I have a '04 C5 coupe with the F55 suspension and the car was lowered on STOCK bolts and put new tires on it. I want to have good tire wear and for it to handle well. I am going to get it aligned. Are the below specs good?
Front Camber: -1.2 degrees per side
Front Caster: + 6 degrees per side
Front toe: 0 to 1/16" total toe out
Rear Camber: -0.9 degrees
Rear toe: 1/8" total toe in
:confused:
[Modified by pettrix, 12:44 AM 5/23/2004]
Old May 23, 2004 | 03:13 AM
Richin Chicago's Avatar
Richin Chicago
Default Re: C5 Coupe w/ F55 Alignment Specs (pettrix)
:confused:
Looks fairly similar to what I had. The guy that did mine asked me to try slightly more camber in the rear which goes against conventional wisdom but I got it out on the track and it felt very solid. Big improvement over stock settings.
Click to enlarge:
Old May 23, 2004 | 08:47 AM
MrEracer's Avatar
MrEracer
-1.2 camber on both front wheels would be great for the track but is not going to be very friendly to the tires...
Shirl
Old May 23, 2004 | 03:55 PM
mountainbiker2's Avatar
mountainbiker2
I would say those settings are very good for track and autocross. Just for cruising probably not. It depends on what's more important to you. Those setting is what I have. My back is -.75 neg. camber. I get pretty even wear all the way around. I road race around more then just cruising.
Old May 23, 2004 | 09:40 PM
LBear's Avatar
LBear
Default Re: C5 Coupe w/ F55 Alignment Specs (mountainbiker2)
So what specs should I go with to get GOOD tire life AND also get good handling on the street?
:confused:
Old May 24, 2004 | 11:02 AM
mountainbiker2
I found this on the search. http://forums.corvetteforum.com/zerothread?id=810354 I'm running Kumho mx and will probably only get 5k on them. Go to search and type in alignment and archives topics and you will get alot of answers. Then make up your mind on what you what to do.
[Modified by mountainbiker2, 10:09 AM 5/24/2004]
[Modified by mountainbiker2, 10:10 AM 5/24/2004]
Old May 24, 2004 | 08:13 PM
Paras's Avatar
Paras
Do you have runflat tires? I've been told that more than half a degree camber on runflats is actually detrimental to handling...
Old May 25, 2004 | 01:31 AM
LBear's Avatar
LBear
Default Re: C5 Coupe w/ F55 Alignment Specs (Paras)
They are standard NON-runflat tires.
To C5 Coupe Alignment Specs
