Newbie, Can't clear code A6 SCM 2860 HC...
Old May 23, 2004 | 12:05 PM
BLK81&99's Avatar
BLK81&99
3rd Gear
Default Newbie, Can't clear code A6 SCM 2860 HC...
Anybody know what this code means? It doesn't seem to be affecting anything on my 99.
I'm a first timer, although I've been watching this site for quite a while. It sure is a great asset to the Corvette community. Thanks. :chevy
Old May 23, 2004 | 04:18 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Default Re: Newbie, Can't clear code A6 SCM 2860 HC... (BLK81&99)
These are the codes that are listed under SCM (I didn't see 2860 listed - might want to check the code on your DIC again) - check out this website: http://97vette.com/howto/codes/index.html:
A6-SCM - Seat Control Module
B0846 Battery 2 Out of Range
B0851 Battery 1 Out of Range
B2002 Fore/Aft Seat Motor Open or Short to GND
B2007 Front Vertical Seat Motor Open or Shorted
B2012 Rear Vertical Seat Motor Open or Shorted
B2172 Seat Front Up Switch Shorted to GND
B2177 Seat Front Down Switch Shorted to GND
B2182 Seat Rear Up Switch Shorted to GND
B2187 Seat Rear Down Switch Shorted to GND
B2192 Seat Forward Switch Shorted to GND
B2197 Seat Reverse Switch Shorted to GND
B2605 Seat Front Vertical Position Sensor Failure
B2606 Seat Rear Vertical Position Sensor Failure
B2607 Seat Horizontal Position Sensor Failure
Old May 23, 2004 | 06:16 PM
BLK81&99's Avatar
BLK81&99
3rd Gear
I've got the same list of codes.
The code I keep getting is "A6 SCM 2860 CH". I've checked it several times.
I'm completely stumped by this one.
Thanks for the input. :confused:
Old May 23, 2004 | 07:01 PM
Gray Ghost GS
Did you do any recent performance modifications that might have set this off? If so, did you troubleshoot the work that was done?
May need to go through the PCM "relearn" procedures - might help. I don't have the procedures, but I'm sure they're available on the LS1HowTo website or on LS1Tech. I believe you need to disconnect the battery or pull a fuse (#25 ?) and reconnect after XX amount of seconds/minutes. Worth a try.
[Modified by AlohaC5, 2:02 PM 5/23/2004]
Old May 24, 2004 | 06:18 AM
BLK81&99's Avatar
BLK81&99
3rd Gear
Default Re: Newbie, Can't clear code A6 SCM 2860 HC... (AlohaC5)
No mods by me. I just purchased the 99' about a month ago and found the code in its memory.
I will try disconnecting the battery to clear it, but I'm still interested in knowing what the code is. I'm guessing it has something to do with the seat controls, but everything seems to work okay.
Thanks Aloha.
:seeya
To Newbie, Can't clear code A6 SCM 2860 HC...
