Little tech help please
Old May 24, 2004 | 09:39 PM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
Default Little tech help please
I bought an LS6 manifold w/coolant lines from Fred Beans May specials and a set of used LS6 heads complete with rockers and push rods from another forum member. My car is a 2000 FRC witht he LS1 obviously.
Aside from the obvious gaskets will I need anything else to make the swaps? Oh I also bought a set of GM 28# fuel injectors, will they work ok with my rails or is something else needed there as well?
Thanks in advance.
:cheers:
Old May 24, 2004 | 10:47 PM
IFLUBYU's Avatar
IFLUBYU
Default Re: Little tech help please (PHPD7102)
Thanks in advance.
:cheers:
Other than gaskets, o-rings, head-bolts, etc., you should be set. Depending on the shape of the heads, you may want to have a machine shop go over them, if nothing else to clean them up and check/mill the deck to ensure they are nice and flat. A little hand polishing/deburring by you or a machine shop can help with better flow.
Nice upgrade, good luck! :thumbs:
