Input shaft question.............
Old May 25, 2004 | 12:37 AM
FreddyG's Avatar
FreddyG
Default Input shaft question.............
How hard is it to change a left side differential input shaft? Could you also tell me what parts are involved with this too? Thanks in advance.
Old May 25, 2004 | 01:32 AM
sick_vette's Avatar
sick_vette
Default Re: Input shaft question............. (LuvmyC5)
Do you mean the l/s output shaft that turns your wheels??
I just snapped mine this weekend and I have heard of this happening quite often all of a sudden. :cheers:
Old May 25, 2004 | 09:36 AM
FreddyG's Avatar
FreddyG
Default Re: Input shaft question............. (blackroadster)
Yes Sir. That's the one that I mean. I saw the same thing, and have a low mileage 3.42 that I'm going to have put in, and thought that I'd prepare it for the install.
Old May 25, 2004 | 11:37 AM
sick_vette's Avatar
sick_vette
You have to pull your diff out. It's an easy install when it's out., if you have worked on drivetrain components before. I'll be doing mine as soon as it gets here. If you wnat I could walk you through it. Since your diff isn't installed yet. All you replace is the shaft. Around $350 is the average. I got mine through DTE. Let me know.
Take it from me, get it done before it's in the car> It will save you alot of money, time and hassels :cheers:
Old May 26, 2004 | 09:29 AM
martin97c5's Avatar
martin97c5
do they make a hardend shaft for the passenger side? because thats the one I broke. Once u install the hardened one on the driver side it now makes the passenger side the weak link.
Old May 26, 2004 | 11:59 AM
FreddyG's Avatar
FreddyG
Thanks! I might have to take you up on that! I haven't heard of anyone snapping the other side (not that it hasn't happened, I just never heard of it).
[Modified by LuvmyC5, 11:00 AM 5/26/2004]
Old May 26, 2004 | 12:15 PM
sick_vette's Avatar
sick_vette
Default Re: Input shaft question............. (martin97c5)
I'm pretty sure DTE makes one for the r/s. You replaced the driver's then snapped the passengers? That sucks. How long after and on what tires? :cheers:
Old May 26, 2004 | 04:22 PM
martin97c5's Avatar
martin97c5
My car run's mid 12's not to powerful, but i have the 4.10 gearing and i was runing 315 bfg dragradials. It basically happened the 1st time i did a burn out and got the tires sticky!!! Be careful out there!!
To Input shaft question.............
