Y2K Tire Choice Q
Old May 25, 2004 | 05:25 PM
Garibaldi's Avatar
Garibaldi
Default Y2K Tire Choice Q
I've got two new Kumho Ecsta MX 255/45/17 [26.1"] tires to mount on stock front wheels. I need to buy two rear tires. Kumho sells 275/40/18 [26.1"] and 295/35/18[26.1"] tires. Any problems with either combo?
Here are two concerns that I'M wondering about:
1) 255/45/17 and 275/40/18 maybe more understeer because of fatter front tire
2) 255/45/17 and 295/35/18 the rear tire is a little wide for a 9.5" rim
Anything you'd like to add and/or suggest?
Regards,
Garibaldi
Old May 26, 2004 | 07:30 PM
Garibaldi's Avatar
Garibaldi
Default Re: Y2K Tire Choice Q (Garibaldi)
TTT
Old May 26, 2004 | 09:25 PM
blackjack's Avatar
blackjack
I believe that the diameter of the fronts must be about an inch smaller than the diameter of the rears to avoid active handling problems.
Old May 27, 2004 | 01:09 PM
Garibaldi's Avatar
Garibaldi
Default Re: Y2K Tire Choice Q (blackjack)
Anybody know where I can find out for sure about this? :confused: :confused:
Garibaldi
Old May 27, 2004 | 01:57 PM
Richin Chicago's Avatar
Richin Chicago
Garibaldi
I can tell you that the C5 system is programmed to see a 4% larger diameter in the rear. In other words when the rear tires are turning 4% slower that the front the ABS and so on assummes all tires are turning at the same speed and there is no slippage.
Old May 27, 2004 | 04:52 PM
yankeevetteconvert's Avatar
yankeevetteconvert
If you use 255/40/17 you will be perfect.It has a 25.1 tire dia.and is almost 2lbs lighter.
To Y2K Tire Choice Q
