A4 torque vs M6
Old May 27, 2004 | 03:08 AM
eaglebusman's Avatar
eaglebusman
Default A4 torque vs M6
Anyone know what the difference is in the A4 and M6 that increases the manuals torque? Is it just in the ECM's program or are there cam, etc changes? I'm talking about the 2004 motors BTW. Thanks :confused:
Old May 27, 2004 | 04:14 AM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
Default Re: A4 torque vs M6 (eaglebusman)
Torque Management on the A4 limits the torque to 300lbs. The motors are the same for the MN6 and the A4. The A4 is slightly more parasitic(requiring more to turn), this is true of all automatics.
Hope this helps,
AZC5
Old May 27, 2004 | 03:10 PM
G-lock's Avatar
G-lock
Default Re: A4 torque vs M6 (AZC5)
Hope this helps,
AZC5
Can you give any more details on TM, does it pull timing or what?? Jeff
Old May 27, 2004 | 04:24 PM
brialex42's Avatar
brialex42
Default Re: A4 torque vs M6 (G-lock)
Best solution is to have the car tuned with LS1 edit and have Torque Management turned off altogether.
Old May 27, 2004 | 08:32 PM
blackjack's Avatar
blackjack
Default Re: A4 torque vs M6 (brialex42)
:iagree: Turn up the line pressure while you're at it and it will run and shift like a whole new car. :D
Old May 27, 2004 | 09:21 PM
Cary's Avatar
Cary
:iagree: ...and upgrade to a Vigilante 2800 TConverter, or some other reputable aftermarket TC w/stall depending on street or track application desired.
To A4 torque vs M6
