L E D Temp on air and heat
Old May 27, 2004 | 10:14 PM
frankb's Avatar
frankb
Default L E D Temp on air and heat
I have a 2000 and the le4d light goes out as I start driving. Everything else is working fine. Can this be fix at home or is this a dealer fix. thanks :confused:
Old May 28, 2004 | 12:44 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: L E D Temp on air and heat (frankb)
what LED?
The one that tells you what temperature it is outside. Does this happen at night too?
[Modified by ICULUKN-C5, 10:45 PM 5/27/2004]
Old May 28, 2004 | 01:58 PM
BHP's Avatar
BHP
I assume you are referring to the HVAC display. It is sealed and must be replaced as unit. Expensive $$$.
Old May 28, 2004 | 08:09 PM
frankb's Avatar
frankb
Default Re: L E D Temp on air and heat (ICULUKN-C5)
Thanks for the replies, The problem is constant now. the led light has not come on at all today. Are you saying that because the light is out I need a new hvac unit? YIKES!!! :(
Old May 28, 2004 | 08:31 PM
02c5Ls1's Avatar
02c5Ls1
acually no after u remove ur dash as if you were installing a short shifter u can then remove the control unit which is held in by i believe just 2 or more screws. you can then dissasemble the unit (have faced down to keep buttons in place) then you should be able to gain access to the led's these may be sorta hard to find ur best bet is going to an automotive electrician if u want the exact led. then just solder the old ones out and the new ones in.. if i remember correctly the leds are pretty out in the open well hope thats any help (also if u dont want to install the leds urself just ask the electrician haha...
Old May 29, 2004 | 07:08 PM
frankb's Avatar
frankb
Default Re: L E D Temp on air and heat (02c5Ls1)
I appreciate all of your help. Sounds like its over my head. Thanks again and this is why this sight is the best. Guess I'll have to spend the bucks when I get some. My wife said no new vette!!! Ha
To L E D Temp on air and heat
