Car cooler with AC on?
Old May 28, 2004 | 01:21 AM
sandmanusd's Avatar
sandmanusd
Default Car cooler with AC on?
Ok, wierd question, but I heard from someone that the Vettes run cooler at idel and what not when the AC is on... explanation given is that the fan runs while the AC is on, which in turn cools the engine.. but when the AC is off, the fan only turns on when engine is 250+... any truth to this? :confused:
Old May 28, 2004 | 01:34 AM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
Default Re: Car cooler with AC on? (sandmanusd)
not exactly. Fan comes on at 226 I believe. If you have the AC on, the second fan comes on as well, but I'm not sure at what temp.
Edit: this is easy to try. start your car and let it idle while watching coolant temp... at 226, fan should come on. turn AC on and off and listen to fan noise.
[Modified by 99C5Vert, 1:35 AM 5/28/2004]
Old May 28, 2004 | 05:59 AM
pure energy's Avatar
pure energy
Default Re: Car cooler with AC on? (99C5Vert)
When the Air conditioning is on,the cooling fans come on.The fans come on with the a/c ,no matter what the temperature is :yesnod:
Old May 29, 2004 | 06:53 AM
ndirishr1's Avatar
ndirishr1
I use this trick when we run 4th of July parades. Definitely stays cooler with the A/C on because the blower runs more.
Old May 30, 2004 | 02:06 AM
sandmanusd's Avatar
sandmanusd
Default Re: Car cooler with AC on? (pure energy)
So it does stay cooler with A/C on then? and the fan runs with AC on. no matter the temp..? :shocked:
Old May 30, 2004 | 02:56 AM
Dope's Avatar
Dope
Resident moron
Yes. This is nothing special, most cars do this. The fans get air moving through the radiator and AC condenser.
Dope
Old May 30, 2004 | 07:38 AM
AFVETTE's Avatar
AFVETTE
During a recent dyno day some cars temps would rise, so they would kick on the AC and sure enough the temps would fall to about 205 or so from well over 220. I know the fans kick on earlier with the AC engaged.
Considering I grew up in the 50 and 60's this concept is alien to me but it sure works when I'm sitting traffic and I see my temps start to creep up, I turn on the AC.
Tom
Old May 30, 2004 | 11:52 AM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: Car cooler with AC on? (AFVETTE)
Try turning the heat on. It will cool the car down as well. I do this while I am staging at the track. Kaley
To Car cooler with AC on?
