Air conditioner Hose
Old May 29, 2004 | 05:45 PM
ROD BROWN's Avatar
ROD BROWN
Default Air conditioner Hose
Can anybody tell me if there is a hose connected to the airconditioner or if I can install one on my car.The water is running down on the exhaust pipes and stinks like mad.I have tried to locate the hole where the water is comming out,but I have the aur on all the time and its so wet i can't locate the hole .anybody out there that can help me? :chevy :chevy :flag :chevy :chevy
Old May 30, 2004 | 10:23 AM
Golf Man's Avatar
Golf Man
Default Re: Air conditioner Hose (ROD BROWN)
Rod, the air conditioner drain hose is mounted along the pass side fire wall
in-line with the rear of the pass side cylinder head. (black tube with a bulb, the size of a small grn pea on the end) If it smells that bad it might be leaking Dex-Cool. While you are underneath looking cut the end off of the drain hose, it is known for plugging up. Hope this helps..........
:seeya
