Changing Brake Pads... Confused member here...
Old Jun 2, 2004 | 06:42 PM
Izover4u's Avatar
Izover4u
Default Changing Brake Pads... Confused member here...
Hey guys, I did a search and found lots of info and many different opinions, you could say... I purchased Raybesto Ceramic pads. Now how do I go about installing them? I never replaced pads before on a C5 so I am Can someone please post how to instructions...
From my search some member say you don't even need to completely remove the caliper, only one pin, swing the caliper down replace the pad, regreese that one pin and your done is this right?
Old Jun 2, 2004 | 07:04 PM
thegypsie's Avatar
thegypsie
Default Re: Changing Brake Pads... Confused member here... (Izover4u)
I'll email instructions from the C5 manual that were sent to me by forum member Patchers
I did my first rotor and pad change last week. Once you are done you will be an old pro.
Old Jun 2, 2004 | 07:05 PM
Old Rotor Head's Avatar
Old Rotor Head
You've got mail
Old Jun 2, 2004 | 07:15 PM
Patches's Avatar
Patches
My work here is done.
Old Jun 3, 2004 | 02:57 PM
BayouVette's Avatar
BayouVette
Default Re: Changing Brake Pads... Confused member here... (Patches)
hey, can I get these instructions sent to
jsevin@rpc.net
Old Jun 3, 2004 | 03:50 PM
G-lock's Avatar
G-lock
Default Re: Changing Brake Pads... Confused member here... (thegypsie)
I'd like the instructions as well. Maybe they should be tech-tipped?? Thanx. Jeff
Old Jun 3, 2004 | 05:14 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
My work has just begun....... nice avatar
Old Jun 3, 2004 | 09:34 PM
Y2k Vette Pilot's Avatar
Y2k Vette Pilot
From: Coastal Sektor, Southern Province, Peoples Republik of Kalifornia
Default Re: Changing Brake Pads... Confused member here... (G-lock)
Possible one more copy??? If so, please email: tbolen@socal.rr.com
your kindness is APPRECIATED!
Old Jun 3, 2004 | 10:23 PM
Jharms's Avatar
Jharms
I've got my first wheel off and am confused about where to put the sticky pad and the greese. I'd sure appreciate a quick copy of these instructions too.
This forum rocks!
jamie_harms@sbcglobal.net
Old Jun 4, 2004 | 12:33 AM
T_Vert's Avatar
T_Vert
Default Re: Changing Brake Pads... Confused member here... (Jharms)
depending on where you are located i can give ya a hand. Im in the northwest burbs of chicago.. IMO its easier to just remove both pins. Id think it'd be easier to compress the pistons in the calipers. ive had my pads/calipers off a few times now but never had to put new pads on just rotors (cross drilled)
Dave
[Modified by TT_Vert, 11:34 PM 6/3/2004]
Old Jun 4, 2004 | 02:14 PM
Lancer033's Avatar
Lancer033
e-mailed instructions for chaning pads and rotors to jamie_harms@sbcglobal.net; jsevin@rpc.net; mitzelj@voyager.net
after you do it once, it's easy
Old Jun 4, 2004 | 03:21 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Default Re: Changing Brake Pads... Confused member here... (Lancer033)
Hehe... Why don't ya just post the directions here.
Old Jun 4, 2004 | 04:22 PM
G-lock's Avatar
G-lock
Got it thanks. One question tho, do you need to replace the caliper bolt(s) when doing this or is it only the pivot bolt that must be replaced when you actually remove the caliper?? Thanx, Jeff
Old Jun 4, 2004 | 10:04 PM
Lancer033's Avatar
Lancer033
just clean them a put new locktite and you're good to go.
[Modified by Lancer033, 9:04 PM 6/4/2004]
Old Jun 4, 2004 | 11:12 PM
HORSPWR's Avatar
HORSPWR
I would like the instructions too if you have time.Been thinking of putting ceramic pads on!E-mail is horspwr2@usfamily.net
Thanks DEB
Old Jun 4, 2004 | 11:35 PM
dlyle's Avatar
dlyle
I'd like the instructions also.. . thanks. dlyle@fordycebank.com
Old Jun 4, 2004 | 11:39 PM
NoWay's Avatar
NoWay
I am getting ready to install brake pads and would appreciate directions emailed, too. Thanks
To Changing Brake Pads... Confused member here...
Old Jun 9, 2004 | 11:46 PM
darioettore's Avatar
darioettore
Hello there;
Can I have the instruction too please? I have a set of HAWK HPS to install this week-end.
Thanks in advance, very appreciated : darioo@mail.com
- Dario -
Old Jun 10, 2004 | 11:08 AM
BAMAGOLFER's Avatar
BAMAGOLFER
St. Jude Donor '06-'10-'11
Can I get a copy also? I just ordered new ceramic pads from Fred Beans. I've never done a brake pad change so the instructions will probably save me some time.
Kelly (kwalker@samc.org)
Old Jun 10, 2004 | 11:24 AM
laketullochvette's Avatar
laketullochvette
just received my G.M. drilled rotors and pads,I would love a copy of the instructions if you would be so kind Gypsie.
john.coutur@pcg.com
