CAGS
Old Jun 5, 2004 | 06:02 PM
GP's Avatar
GP
Cruising
Default CAGS
What are the proper installation instructions for installing a CAGS on a 2003 Z06?
The part that I purchased has instructions for a 1997-2001 model.
I went to install the bypass and I could not see the wire loom or plug that connects to the transmission.
HELP!!!!!!!
Thanks, Greg
Old Jun 5, 2004 | 09:22 PM
goinpostol's Avatar
goinpostol
Default Re: CAGS (GP)
On the drivers side of the tranny, almost exactly where the exhaust goes over the axle, there is a plug in the side of the tranny. It's up there pretty far, but easy to get to.
-Steve
Old Jun 6, 2004 | 05:05 PM
GP's Avatar
GP
Cruising
Found it!
I am a new Corvette owner and I was looking under the car in the area where "conventional" car transmissions are located. I didn’t realize that the Trans was that far back. Once I found it, it took about 3 minutes to install the CAGS elimination plug.
Thanks for the help.
Greg
Old Jun 11, 2004 | 05:45 PM
Classic-Chevy-Guy's Avatar
Classic-Chevy-Guy
Can I get to the CAGS cable by putting the front end up on Rhino Ramps (about 9-10"), or do I need to put the car up on the lift?
Old Jun 24, 2004 | 11:45 PM
mdhmi's Avatar
mdhmi
It would be much easier to remove CAGS via LS1-Edit. Much cleaner..
Mark
Old Jun 25, 2004 | 12:00 AM
Avanti's Avatar
Avanti
It's clear you are not yet ready for a Z, so let me know when I can come take it off your hands and leave you a LeSabre in exchange...
Seriously... there is nothing wrong with the little aftermarket "thingee"/resistor pack. You don't have to deal with an "edit."
As for how to get to it, simply drive the rear up on a couple 2x10's or 12's, whatever as long as you get it up a few inches and it is SAFELY supported AND blocked! The C-5 is relatively easy to get to the underside from the rear if you aren't "portly." I'm thin and had no problemo.
All the best.
Old Aug 20, 2004 | 04:03 PM
RED Coupe's Avatar
RED Coupe
Mark
What's LS1-Edit?
Old Aug 21, 2004 | 03:47 PM
JC in XTC5's Avatar
JC in XTC5
Since the tranny is at the rear, you can get to it by backing the car up on Rhino Ramps.
Old Aug 21, 2004 | 04:26 PM
mdhmi's Avatar
mdhmi
Originally Posted by RED Coupe
What's LS1-Edit?
LS1-Edit is a software package that allows you to interface with the PCM. I had CAGS removed via a few small changes to my PCM ( while they were at it they adjusted my fan temps ). You should be able to find a tuner with LS1-Edit that is willing to remove CAGS, adjust your shift points (if you have an A4), adjust fan temps, etc for $100-$150.
Cheers,
Mark
To CAGS
