have 98 wrecked on pass front and need help to find replacement ecu and mainly engine wiring harness....any suggestions...gm is out and will not have for a while. maybe new, rebuild, used or any rebuilders i can send mine to. the harness was cut at the ecu both pins...
Re: 98 ecu and engine wiring harness (ANTHONYCORVETTE)
This does not bode well for the longterm maintence of the C5. GM is out of them? Disgraceful! :mad
FWIW, demand will be less for the 97-98 parts than for later years just due to having produced fewer vehicles. But yeah, with the battery placement such as it is I'd like to know they were well stocked up.
