Bassani or Corsa Crossover Pipe
Old Jun 25, 2004 | 11:24 PM
Lemans04's Avatar
Lemans04
Default Bassani or Corsa Crossover Pipe
I plan to have the Corsa Indy Pace Car Exhaust install on my new 04' C5 and I trying to decide which crossover pipe to use Bassani or Corsa.........Recommendations??
Old Jun 25, 2004 | 11:26 PM
mdhmi's Avatar
mdhmi
Default Re: Bassani or Corsa Crossover Pipe (Lemans04)
Either. Personally, I would try for a matching system.
Mark
Old Jun 26, 2004 | 08:50 AM
birch64's Avatar
birch64
just ordered a magnaflow x-pipe, from west coast corvette. they say mangaflow is a true crossover x-pipe..
Old Jun 26, 2004 | 10:17 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Default Re: Bassani or Corsa Crossover Pipe (mdhmi)
Tom
Old Jun 26, 2004 | 10:24 AM
VETFVER's Avatar
VETFVER
The X-pipe will turn the volume of sound down and stop all the popping on decelaeration a must for the Corsa System. Don't expect any more HP as a result. You do an X-pipe to adjust sound.
Both Magnaflow and Corsa will work equally well.
Dan
Old Jun 26, 2004 | 10:27 AM
DeJay's Avatar
DeJay
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
I got the Corsa Indy catback exhaust and I got Corsa crossover pipe.
Old Jun 26, 2004 | 10:28 AM
Flareside's Avatar
Flareside
I have the Corsa. Great product. I was amazed how much it mellowed the sound and reduced the popping. IMO, you need one of these with any aftermarket, louder than OEM system.
The only thing I didn't like about the Corsa were the flanges where the mufflers bolt to the X. Corsa doesn't thread the thick metal flange like GM does, so you have to run a nut and bolt at the joint instead of just a bolt like OEM. Just one more thing to loosen and fail. (and they included an SAE nut and bolt for an all metric car, WTF?) I'm not sure how the Bassani is built.
[Modified by Flareside, 10:38 AM 6/26/2004]
To Bassani or Corsa Crossover Pipe
