Power Window Failure
Old Jun 26, 2004 | 04:01 PM
2K6Ls2's Avatar
2K6Ls2
Default Power Window Failure
My 03 C-5 is for the most part driven only by me and as such the passenger window is rarely used. The car has 17,000 miles and today I tried to roll down the passenger window and it doesn't move. I can hear sounds from the door panel but no movement. I tried from the right and left door contol module. Any thought/suggestions?
Old Jun 26, 2004 | 04:57 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Default Re: Power Window Failure (2K3Ls1)
This is a common problem for the C5. In fact, you will find numerous posts on this via the search function. Your warranty will cover the replacement of the window regulator. Mine went in my '04 with only 6K miles on it.
Old Jun 27, 2004 | 03:20 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Try tapping on the passenger side window down button several times. it will finally budge.
you need to use the passenger switch on a reg basis.
[Modified by eamador11, 2:21 AM 6/27/2004]
To Power Window Failure
