GAS LID WONT OPEN PLEASE HELP
Old Jun 26, 2004 | 04:27 PM
turbo altezza's Avatar
turbo altezza
Default GAS LID WONT OPEN PLEASE HELP
it opened for me on the way to gainsville to get gas but when i got here and needed to fill up it wouldnt open. so i took the dash apart and checked the wire and it looked fine, i also unpluged it and pluged it back in and it was fine but the lid still wont open. so to get it open i took a flat head and put it under the lid and poped it open. I dont know what to do........
Old Jun 26, 2004 | 04:31 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Default Re: GAS LID WONT OPEN PLEASE HELP (turbo altezza)
Open the hatch, look left (where the filler neck is) you will see a steel cable. Pull the cable and the gas cover will open. I would check the fuses and see if any are burned out.
Bob
Old Jun 26, 2004 | 04:33 PM
turbo altezza
Default Re: GAS LID WONT OPEN PLEASE HELP (16Again)
what hatch?
Old Jun 26, 2004 | 04:34 PM
69's Avatar
69
Cruise-In VI Veteran
If your fuel filler door release won’t operate, there is a
manual release tab. The tab is located against the upper
trim on the driver’s side in the rear compartment.
Old Jun 26, 2004 | 04:37 PM
16Again's Avatar
16Again
what hatch?
TRUNK area......
Old Jun 26, 2004 | 04:38 PM
turbo altezza
Default Re: GAS LID WONT OPEN PLEASE HELP (69)
i cant find eaither of what you two have said. BTW I HAVE A Z06 dont know if that makes a diffrence
[Modified by turbo altezza, 9:59 PM 6/26/2004]
Old Jun 26, 2004 | 04:54 PM
69's Avatar
69
There is a photo of the tab location in the owners manual, do you have this manual with you?
Old Jun 26, 2004 | 04:56 PM
JC in XTC5's Avatar
JC in XTC5
Check the owner's manual to see where the manual release is. I'm not sure if the Z06 is different, but the coupe has the manual release.
If you open the trunk of your car and look along the driver's side of the trunk towards the back seat, and possibly up under the lip of the trunk fender, there should be a steel cable with a small handle. It's probably not visible unless you lean into the trunk and fish around.
Good Luck.
[Modified by JC in XTC5, 4:56 PM 6/26/2004]
Old Jun 26, 2004 | 05:00 PM
turbo altezza
Default Re: GAS LID WONT OPEN PLEASE HELP (JC in XTC5)
no i dont have the manuel can anyone take a pic or scan
Old Jun 26, 2004 | 05:17 PM
69's Avatar
69
I sent you my manual via e-mail.
To download your manuals for free, register, go here
https://www.mygmlink.com/main/US/en/gm/home
Old Jun 26, 2004 | 05:21 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The release cable is on top of the fenderwell on the left side, if you open the trunk you'll see the left rear fenderwell, look and feel around this area, if you still don't have any luck pull the carpet back, it's there
Old Jun 26, 2004 | 05:33 PM
16Again's Avatar
16Again
If you can't find it tonight, feel free to take a ride over to Boynton tomorrow and i'll show you where it is.
Bob
To GAS LID WONT OPEN PLEASE HELP
