good thing its got a rev limiter
Old Jun 28, 2004 | 08:33 AM
wrustywrench's Avatar
wrustywrench
Default good thing its got a rev limiter
used to my manual valve body street rod,, tried doing a burnout starting in low,, well the shift lite come on a 5 grand and I shifted,, hit the rev limiter before it shifted,,,drats,,,at least no harm was done,, I have found its way better to leave it in drive and stand on it....what harm is done by hitting the rev limiter,,,should be none as I see it,,,,
Old Jun 28, 2004 | 08:40 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Default Re: good thing its got a rev limiter (wrustywrench)
Have to work at it a little to hit the limiter with an A4 don't ya? No harm, no foul but I wouldn't make a habit of it.
Old Jun 28, 2004 | 09:33 AM
wrustywrench
Default Re: good thing its got a rev limiter (ToplessTexan)
Its not hard to hit when shifting manually with 3.73 gears and a maggie...I try to not make a habit out of it
Old Jun 28, 2004 | 10:08 AM
Garibaldi's Avatar
Garibaldi
It's Monday; I'm nostalgic. When I was a kid, I worked a Porsche dealership service department. Naturally, we all paid attention to Mark Donahue in the 917s. At the time, Porsche gave Penske the race cars and everyone else got the "customer cars." Donahue and Penske got a couple of 917s and a bunch of motors for testing. Donahue went out and proceeded to blow up the motor in short order. New motor in, check the old one: bent valves, etc. Donahue goes out again and blows up the second motor. Penske looks at the second motor, same thing: all busted up.
Penske: "Mark, what are you shifting at?"
Donahue: "I don't know..."
Penske: What do you mean you don't know?"
Donahue: "I mean I don't know. You told me it had a rev limiter, so I wait til I hit the rev limiter before I shift..."
BTW this has nothing to do with modern rev limiters. If 917s were like other Porsches at the time, the rev limiter was mechanical, not electronic.
Old Jun 28, 2004 | 10:55 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I've got the same setup and it's very easy to hit the rev limiter, even from a 40 mph roll
Old Jun 28, 2004 | 10:56 AM
wrustywrench
Default Re: good thing its got a rev limiter (runamuk)
runamuk , you got that right,,,,,any problems with your set up. mine has been great...
Old Jun 28, 2004 | 08:06 PM
ToplessTexan
Guys, this one goes in the pilot error column :bb The PCM can do a more accurate job shifting the tranny if you'll let it. The only thing I really use the shifter for is engine braking from time to time. I do remember playing with shifting manually at the strip one day. Pretty funny hearing an A4 whap on the limiter... Sadly at this particular track the return lane was between the grandstand and the track so you had to pass the crowd twice.
To good thing its got a rev limiter
