engine codes
Old Jun 28, 2004 | 06:50 PM
hdvsilver's Avatar
hdvsilver
Default engine codes
Hay fellow corvette owners, just recently I had a set of Bassani LT headers installed with a set of cats, after about a hundred miles or so I statred getting some codes they are p0133 , p0153 , p1133 , p1153 can anyone give me some help with this, my vette is 2003 Ls1.
Old Jun 28, 2004 | 06:55 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Default Re: engine codes (hdvsilver)
These are 02 sensor codes. Did you install 02 Sims or reattached your 02 sensors after the header install? That would be the first thing I would check. See if the wiring is crossed too.
Old Jun 28, 2004 | 07:16 PM
hdvsilver's Avatar
hdvsilver
Default Re: engine codes (AlohaC5)
Yes I did install the sims.
To engine codes
