can i reuse headgaskets???
Jun 29, 2004 | 07:31 PM
i have about 800miles since the last heads swap. will they be any good or should i change um. cant wait to get the afr's on
Jun 29, 2004 | 07:37 PM
Re: can i reuse headgaskets??? (pdd000)
change them unless then are a spring metal head gasket like a cometic
dave
Jun 29, 2004 | 07:59 PM
As a rule any gasket that is compressed is a one time use, although in a pinch I have re-used some gaskets, I would never re-use head gaskets, too much chance for additional complications.
Jun 29, 2004 | 08:04 PM
You are kidding? Right? :p:
Jun 29, 2004 | 09:23 PM
Re: can i reuse headgaskets??? (Triple_Wild_Bill)
i kinda figured id have to change them, but last time i changed the heads a few months back the gaskets looked like new but i changed them anyway. i already have a new set waiting to go
Jun 30, 2004 | 12:21 AM
I don't think reusing a gasket would be worth the risk!
Jun 30, 2004 | 01:47 AM
Re: can i reuse headgaskets??? (jrose7004)
NO............unless they are copper and you heat them almost rehot and quench them in water..........I'd just get new ones......
Jun 30, 2004 | 08:44 AM
Jun 30, 2004 | 10:04 AM
Senior Member
Cruise-In V Veteran
Jun 30, 2004 | 12:51 PM
Re: can i reuse headgaskets??? (NV MY C5)
oh, you can re-use them,,as many times as you want.....if you want leaks....for the price of gaskets,,,please buy new,, some of the race gaskets can be re-used, but I am not sure, GET new.........
