Weiand Intake
Old Jun 29, 2004 | 09:38 PM
jjk2509's Avatar
jjk2509
Default Weiand Intake
Is anyone using the Weiand intake and if so are you having any problems?
I want to purchase the polished LS6 for show more then performance but want to make sure it works without problems.
Old Jun 29, 2004 | 11:26 PM
jjk2509's Avatar
jjk2509
Default Re: Weiand Intake (jjk2509)
ttt
Old Jun 30, 2004 | 12:25 AM
jjk2509's Avatar
jjk2509
Does not look good for the Weiand.
Someone must have one.
Any help?
:flag
Old Jun 30, 2004 | 12:36 AM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
A few months ago I saw a mag article (I don't remember where) dyno testing all the various manifolds.
The Weiand came in last-as I remember about 20 HP lower than LS1/ZO6.
But they indicated that it had a lot of meat in it to port out.
I have no idea what the results of that would be if really hogged out!
Roy
Old Jun 30, 2004 | 12:43 AM
hightest's Avatar
hightest
I tried the Weiand and had alot of high temperature issues. I think the Weiand would be a great intake manifold if you were running nitrous (dry system) as the runners are quite beefy and can be easily drilled or ported, but other than that the composite intakes don't hold as much heat and are also significantly lighter.
Just my $.02.
by the way I switched back to an LS6 manifold after only 1 month.
Old Jun 30, 2004 | 01:02 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I knew when they came out that they were a POS... one time at an autocross I saw a guy with one on his car... So I asked him some technical questions regarding the new intake. I was really hoping to hear something positive about that new intake.. since he didnt know the answers to the questions I was asking... he got pissed off at me.. I tiied to explain that that intake was best suited for large CI engines as it was something that could be ported... Oh well... its his car and if he wants to put stuff on it that makes it slower.. then so be it!
VR
[Modified by vetterdstr, 10:04 PM 6/29/2004]
Old Jun 30, 2004 | 01:23 AM
jjk2509's Avatar
jjk2509
Default Re: Weiand Intake (vetterdstr)
Are the Weiand intakes still a POS?
Need to know. To much money for problems.
Old Jun 30, 2004 | 07:23 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
I researched this recently, I wanted it for the wow factor to go along with the direct port nitrous system. That intake lends itself to heat soak - a better solution is to either paint your manifold, or go to kewl products and get one of thier intake covers... They look great!
Old Jun 30, 2004 | 11:11 AM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default Re: Weiand Intake (7.0sc SuperVette)
I agree a number of tuners tried them when they first came out and the heat soak issue cost 20 to 30rwhp in all the reviews I read at the time--I have read nothing on anyone hogging one out however, maybe its possible to hog one out and make enough power to compensate but I would be surprised if hogging any manifold would give back 20 to 30rwhp--
Old Jun 30, 2004 | 11:43 AM
Lawdogg's Avatar
Lawdogg
Active Streak: 90 Days
Default Re: Weiand Intake (NEPTUNEBILL)
I had one of the Weiands chopped up and bolted to adapter plates to match up with my C5R heads. Under this configuration it is a big POS as it can't flow enough air above 6000 rpms for a 4 banger. It does heat soak, but the dyno indicated loss is less than 10 rwhp.
Old Jul 1, 2004 | 12:08 AM
vetterdstr's Avatar
vetterdstr
Stay away from them!!
VR
To Weiand Intake
